Another Check Engine Light Thread
I have a 2004 Pacifica with 112,000 miles. The check engine light is on, and stays on. The EGR valve has been replaced, new gas cap is on the car, and the EVAP sensor in the gas tank has been replaced. The light shut off for 24 hours after the cap and EGR valve were replaced, just long enough for the car to pass emissions testing. Now it's back on again. The car otherwise runs fine. Does anyone have any ideas?
need to know what the codes are to start with
I'm being told that the code is PO440.
P0440-GENERAL EVAP SYSTEM FAILURE
When Monitored and Set Condition: P0440-GENERAL EVAP SYSTEM FAILURE When Monitored: Engine Running. Fuel Level greater than 12%. Ambient Temperature between 4°C and 32°C (39°F and 89°F) Set Condition: The PCM does not see the NVLD swtich close during the medium/large leak test. The PCM then will increase the vacuum supply to the EVAP system by increasing flow through the EVAP Purge valve. If the switch does not close with an increase in vacuum an error is detected. Two Trip Fault. POSSIBLE CAUSES GOOD TRIP EQUAL TO ZERO VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION VISUAL AND PHYSICAL INSPECTION EVAP PURGE SOLENOID VACUUM SUPPLY INSPECTION EVAP PURGE SOLENOID NVLD SWITCH OPERATION GROUND CIRCUIT OPEN NVLD ASSEMBLY NVLD SWITCH SIGNAL CIRCUIT OPEN EVAPORATIVE EMISSION LEAK DETECTION PCM |
My mechanic is telling me that there may be a crack in a line running from the gas tank, and the trank(s) will have to be dropped to check this possibility. Does this make sense?
| All times are GMT -5. The time now is 05:36 AM. |
