Brake fluid: dot3 or dot4?
As per title, it doesn't say on the manual and I can't find any useful info anywhere on the net, not even here.
It should be a simple question for most of you here, right? Pacifica 2004 Thanks so much! |
DOT 4 has superseded DOT 3 in most cases.
Thanks!
So I should replace it because I don't know what's in it, or you think it's already dot4? Just trying to figure out if mine is one of those "cases". Thanks! |
DOT 4 has been the standard since 2006 and is fully compatible with older DOT 3
Mine is a Stonewhite 2004 Pacifica, and I am running DOT 4
OK, sounds good, so you think I can top up with Dot4 regardless of what I have already in the system? I know it would be better to flush the whole system, but otherwise, they can mix, right?
Thanks! |
