Buster rocker arm, chewed up cam
As the title says, I have a busted rocker assembly and it chewed up the cam on my 05 Pacifica 3.5.
I assume I have to remove the timing belt, timing gear, and exhaust manifold to remove the head cylinder but if someone has any detailed instructions on what needs to be done step by step would be great. Thanks |
Get a shop manual. That's major surgery.
^agree 110%.... this is a pretty big thing and you will have to get shop manual to get torque specs, sequences, etc. IMHO...Look how much a long block would be. What I have found doing some of these things is once I get into it, I find 20 other things that were all linked to the problem and by the time my labor, machine work, headaches, and parts are done, SOMETIMES it as expensive and a remain engine (I find this a lot in hondas.) Not sure how much these engines are but it would be worth wild looking.
