a/c front blower not working
Old Jul 14, 2007 | 06:22 AM
harryvil's Avatar
Default a/c front blower not working
my pac 2004, a/c front blower not working the rear blower is good
Old Jul 14, 2007 | 08:05 AM
Default RE: a/c front blower not working
blower motor resistor under pass side dash
Old Jul 15, 2007 | 06:13 AM
harryvil's Avatar
chrysler tech is this the one that the call it power module// thanks anyway
Old Jul 15, 2007 | 11:26 AM
yes if u have ATC or auto temp control yes its a power module
Old Jul 15, 2007 | 04:50 PM
harryvil's Avatar
chrysler tech ,I check all the wires from the module 1 wire w/c is LT BLUE coming from the ATC crtl no power (no juice)
at all. so I think the problem is from the control. thank s for your help!
Old Jul 15, 2007 | 09:30 PM
here ya go
[IMG]local://upfiles/1033/EE1327465E9E4CD8A0CB94DFE5D26118.gif[/IMG]
Old Jul 16, 2007 | 06:39 AM
harryvil's Avatar
chrysler tech, thank you so much for your attachment. by the way I look at the drawing, from ATC wire to power module ther is no power . so they I look at it the problem will be the ATC, b/c all the fuses& relays are OK. I will ask you about this ATC, where is it located.
Old Jul 16, 2007 | 04:54 PM
its the ac control head the thing u use to change the temp and fan speed. Look at the diagram again if u dont have ne power U mean to control the fan or to run the fan? That DB/LB wire all it does is send amux signal to the module and then it goes from there. The fan itself is just an output of the module. There is a main fuse 40 amp that gives the module all its power. All of the times I have run into this its been the module but if u want to spend ooo 400 or so and take a guess its the control head be my guest.
Old Jul 20, 2007 | 07:38 PM
harryvil's Avatar
it's fix already thanks to chrysler tech good job
Old Jul 20, 2007 | 07:55 PM
what was it ne way the module?
