a/c front blower not working
my pac 2004, a/c front blower not working the rear blower is good
RE: a/c front blower not working
blower motor resistor under pass side dash
chrysler tech is this the one that the call it power module// thanks anyway
yes if u have ATC or auto temp control yes its a power module
chrysler tech ,I check all the wires from the module 1 wire w/c is LT BLUE coming from the ATC crtl no power (no juice)
at all. so I think the problem is from the control. thank s for your help! |
here ya go
[IMG]local://upfiles/1033/EE1327465E9E4CD8A0CB94DFE5D26118.gif[/IMG] |
chrysler tech, thank you so much for your attachment. by the way I look at the drawing, from ATC wire to power module ther is no power . so they I look at it the problem will be the ATC, b/c all the fuses& relays are OK. I will ask you about this ATC, where is it located.
its the ac control head the thing u use to change the temp and fan speed. Look at the diagram again if u dont have ne power U mean to control the fan or to run the fan? That DB/LB wire all it does is send amux signal to the module and then it goes from there. The fan itself is just an output of the module. There is a main fuse 40 amp that gives the module all its power. All of the times I have run into this its been the module but if u want to spend ooo 400 or so and take a guess its the control head be my guest.
it's fix already thanks to chrysler tech good job
what was it ne way the module?
| All times are GMT -5. The time now is 01:12 AM. |
