Change pcv valve
Pacifica likes to burn a quart of oil every 700 to 1000 ish miles depending how I drive. Research on it says to change the pcv valve. Is it hard and happen by chance have a how to? Can't find anything on YouTube. Thanks in advance.
What oil are you running? The Chrysler spec is a thin oil, I believe 10-30. When my Pac was brand new, it was drinking about a quart per 1000 miles. Quickly wiped out the catalytic converter. Went to 10-40 at about 30k miles, started getting about 2500 miles per quart. Have always changed the oil at 6k. Currently at 320k miles, using 10-40 and no issues whatsoever. Have never touched the PCV valve.
10-30 didn't think you could use anything else and go to 10-40
