Convert OEM High Intensity to Halogen
Hi,
We have a 2004 Pacifica with OEM high intensity headlights. The low beams are fogged on the inside and are dim. The assembly seems to be sealed shut so I purchased two standard replacement headlight assemblies not realizing that ours had the high intensity option. Can I use the standard replacement headlight assemblies if I go to Pick N Pull and get the appropriate harness/connectors? Thanks, Bob |
