Daytime Running Light reply
Thank you kkodal78. If you read this would you give me the name of the dealership that turned on your DRL? I would like my dealership to contact them.
RE: Daytime Running Light reply
I also would like the name and contact at the dealership. They have tried several times to turn them on in my 2007 Pacifica Touring AWD with no luck.
They have taken me in the shop area and hooked up the "Star Scan" or whatever the proper name is and showed me that it will not allow them to change the country code although the CC is listed in the menu. The wife and I HAVE to have DTR, looks as though we may have to go with "after market" of some type. Fang |
Fang, I too have a 2007 touring. I checked the aftermarket in Sioux Falls,SD and was told there is none available as the Pac system is computerized.
here is the dealer where i got mine turned on.i am not sure if the 2007 has DRL's i think they use the amber signal lights as DRLs.they are brighter than usual signal lights but give it a try.it won't hurt nothing. Good luck to you all!!
here is the name ,adres and phone # Walker Chrysler Jeep Dodge 95 LOOP ROAD CENTERVILLE, OH 45459 Phone: (937) 434-9500 hope this helps. |
Thanks for the ifo kkodal78
I will give it to my dealer. SDHUSKER: I have seen a couple of places that advertise aftermarket lights but did not inquire if they would work on the 2007 Pac. |
no problem!hope you'll be able to get the DRLs turned on...
if you want the DRL's so bad and can't be turned on then you can do this, if you have auto headlight option put a black tape over the sensor behind the rear view mirror that turns the auto headlight on which will keep the headlights on all the time and if you don't have the auto headlight option see if you can up grade to auto headlight. mine did not have a lot of the options available but i got most of them on myself. now mine has the projection headlights,fog lights,auto headlight /dimming mirror,roof cross bars,intermezzo with sub,K&N air filter,bumper scratch pad,DRL's turned on etc.it makes me feel much better when i can do something on a car which upgrades it.next thing i want to do is to get rear park assist sensors.after that navigation hopefully...so you might be able to get the headlights work for you as DRL's automatically soo good luck. KKODAL78 |
