Dodge Stealth 1994 daytime running lights
Hi,
if you motor in Canada your head lights have to be on like 60 % of high beam. I see in The USA some states will also implement this idea. Lights wont shut off or don't come on any more? Did quite a bid of research on this and if the original mosfet is burned out, there is a problem sub-ing it. So, i ended up building a heat-sink assembly with two mosfets and the interlock wiring to the original module. If you need any help let me know Regards Armin |
| All times are GMT -5. The time now is 05:44 AM. |
