Driver and passenger power seats not working
Old Jan 16, 2008 | 06:22 AM
clueso21's Avatar
Default Driver and passenger power seats not working
Driver and passenger power seats suddenly stopped working.
Old Jan 16, 2008 | 02:16 PM
moe's Avatar
moe
Default RE: Driver and passenger power seats not working
i would look at these fuses 40 and 41.in the ipm under the hood.
Old Jan 16, 2008 | 02:53 PM
if good I have seen the memory seat modules crap out
Old Jan 22, 2008 | 10:54 AM
clueso21's Avatar
I reset breakers . Actually I swap out two breakers and the seats are working. Thanks for the Input
Old Feb 1, 2008 | 02:51 PM
barrr's Avatar
I have a 2005 Pacifica with heated front seats. My power seat controls, heat controls for both passenger and driver seats just quit working. The brake pedal height positioner also quit working. All other electrical compents worked. Checked fuses in box under the hood and all were good. I read about resetting a circuit breaker on this thread. Can someone step me through where these are located. I have looked under the seats and see just a cable connection. I have looked under the dash and there is this huge module, which I am not sure I want to mess with since I can live with power seats not working but not the whole car working. I AM electrically inclined and have worked on most of my previous cars, which were easy to work on. However, I am hesitant to start pulling apart cables on such a sophisticated electronic system. I have the Nav, DV, rear heated seats etc on this car.
Any help would be appreciated. If Ican fix it myself I could save myself the $50 deductable that I would need to pay with my extended warranty.
Thanks in advanvce.
Old Apr 11, 2016 | 09:39 PM
sonuk's Avatar
Default 2006 Pacifica Power Seats Not Working
How did you reset or swap out the breakers? I checked the fuses in the IPM (under the hood) and they were all good. I keep being told there are breakers on the wire harness - if that's true where are those harness/clips located? Thanks much in advance! I was going to buy a replacement Power Seat Memory Module cause I was thinking that may be it.
doctorgee
Jul 15, 2024 08:42 AM
otrebmu
Feb 3, 2015 03:24 PM
Brenda Elizondo
Apr 13, 2013 02:01 PM
pacifica0621
Jul 15, 2011 09:43 PM
volly
Jan 2, 2010 09:32 AM
