Dumb question: Mode door or Blend door actuator?????
To be or not to be...
Thermostat and control panel work just fine. Not able to change where the air blows, including defrost. It just comes out of the middle/main vents. Am I looking for the blend door actuator or the mode door actuator? Are those two names for the same part? |
key words BLEND AIR aka hot cold MODE aka vents
That's what I thought, but I seem to get some confusion from others as well. It also seems there are way more blend actuators available than mode actuators as I search, and they kind of look the same.
if the part numbers the same then they will work if not u can take your chance then
| All times are GMT -5. The time now is 01:28 AM. |
