Front fan issue / on high speed all the time
I own a 2004 Chrysler Pacifica, and the front fan stopped working. I replaced the front blower motor resistor with three (3) new ones. I know the man at the local AutoZone who took them back. Replacing this unit with a new one did not fixed the problem.
What I discovered if I run a wire between the negatives of the blower motor resistor (black to black/orange wires) the fan stay on high speed and nothing on the control unit (changing the fan speeds or turning the unit on/off) changes the fan speed from being on high. Do you know what the issue is with my car? I am clueless at this point. |
get a test light and check for the power and grounds at the resistor and the motor itself
By testing this
I will test power and grounds at the front blower motor resistor and fan motor and this weekend? By testing this, what am I trying to narrow down to be my problem – i.e. a bad fan motor or something else?
power will be there all the time ground will come from the ac control head through the resistor unless u have the auto temp control them its pulse with modulated and u cant test it.
I appreciate you taking your time in helping me resolve my problem. My car has an automatic climate control with dual tempature.
Not sure what my next step should be. |
Hi.
If you have the auto-climate control, fan speed is not controlled with a simple resistor pack. It is a pulse-width modulated 'Blower Control Module' like this: CARAVAN TOWN COUNTRY BLOWER MOTOR RESISTOR MODULE MOPAR | eBay The typical failure mode is that the fan runs uncontrollably at high speed regardless of the the manual setting - you'll see the 'speed bars' on the display change, but the fan will run full speed. Remove/replace procedure is the same as the resistor pack. |
And...the failure is usually the MOSFET power transistor in the module. If you are handy with a soldering iron and so inclined, look up online or visit your local electronics supply house and buy a Fairchild N-channel MOSFET part number HUF75343P3.
The MOSFET will cost you ~$2.00-$3.00 The entire module is $50-$100. I have repaired several with good results and no further issues. |
Goldsmi -
I purchase and tried three (3) new blower motor resistors, and "the typical failure mode of the fan running uncontrollably at high speed regardless of the the manual setting - l do see the 'speed bars' on the display change, but the fan will run full speed." Still happens. The only twist to make the typical failure happen is that I need to run a wire between the negatives of the blower motor resistor (black to black/orange wires). If I do not run the wire, the fan does not blow at all. |
Please clarify - You stated previously that you had auto climate control - You need the 'Blower Control Module'. You should not be trying to use the resistor pack.
a/c Heater blower control switch
The part I replaced three times is the a/c Heater blower control switch. Below is the link.
Duralast/A/C Heater Blower Control Switch (JA1623) | 2004 Chrysler Pacifica AWD 6 Cylinders 4 3.5L SFI SOHC | AutoZone.com_ I do have automatic climate control with dual control. The only way for me to make my fan run on high and have the typical failure you described is to run a seperate wire between the negative (black to black & orange) of this switch. Not sure why the grounds are not connect between the two plug in on this unit. |
