Hated Seat problem
I have a problem with the Heated Seats in my 05 Pac...
When I engage either of the front seat switch to turn on the heated seats, nothing happens. The switch doesn't light up and of course the seats don't heat up. I've looked for a Fuse, but nothing is listed. And I assume that if there is a fuse, it more then likely wll be shared with some other devices. But with the exception of the non-function heated seats, everything else is working just fine. Any ideas? What should I look into/check/test. I could believe that one or the other seat heater is malfunctioning, but both? Cheers!! |
not sure if i can help , due to my seats love me. i give em leather treatment all the time. it would suck if they hated me.:(
ok , your problem - im no tech , only thing that i can think of is maybe a blown relay. they are under the hood , and possibly marked as to what their purpose is? |
Thanks for the info... I haven't been able to locate any relay(s) or fuse for the Heated Front seats... Except for the Rear Heated seats which my Pac doesn't have. But yet I have a fuse in that location (it's fine BTW).
Is it possible that, due to my current outside/inside temperatures (higher then 10C) the seats don't activate until the temps are under a certain range? i.e. say -10c Cheers! |
Originally Posted by Grenadiers
(Post 64594)
Cheers! thats a negative ghostrider. we need to locate the relay for this seat. i dont know anything about your type of auto , just trying to toss in a little help. im thinking its gotta be a relay. maybe even a fuse , im sure you could find all kinds of usefull info with google. |
Took a fast glance through my manual. Check fuses 3, 46 and 47 for starters.
Originally Posted by busboy4
(Post 64616)
Anyone have any idea where (or if) there is a relay for the Front Seat Heaters and where it would be located...? Cheers!! |
Both seats or only one not working?
(Post 64750)
do u have power adjustable pedals?
(Post 64757)
However, the back doesn't adjust on the Drivers side (Lumbar function works fine). When I activate the switch to move upper back, I can hear something working, but no movement... Not sure if that is related. Thanks for your help BTW! Cheers! |
