Headlights shut off when activating high beams
2008 Pacifica. Headlights shut off when using high beams. Multi-switch? Anyone ever experience this before?
I believe the system is designed that way because my PAC does the same thing.I've changed bulbs (even LEDs ) and the headlights always shut off when turning on the high beams. It was suggested that it might be a grounding issue in the relay circuit. However, since I don't often drive using the high beams I'm not to worried.
Does the headlights and high beams stay on when you "flash" your high beams? |
