High Idle Speed issue (Pacifica 2005 3.5L)
Hi to all! I urgently need your help. I replaced the spark plugs on my Chrysler Pacifica 2005 3.5 L. After that, I tried to start the car. It started up but with very high idle speed. After a couple of seconds, the car turned itself off. Every time I start the car, this problem repeats. All hoses checked and bolts spun. Any idea? Maybe I damaged the sensors?
Thanks a lot in advance Alex |
There is a Mass Airflow Sensor mounted on the black rubber air intake tube. It can be easily damaged (or left out) when doing the plugs on a 3.5. Can you verify MAF sensor is in place and functional?
Originally Posted by djetelina
(Post 109194)
but I figured out that U have a bad vacuum leak where egr tube goes into upper intake... missing gasket. https://cimg4.ibsrv.net/gimg/www.chr...905693d4f.jpeg |
Originally Posted by amivo
(Post 109195)
I am not sure.. but I figured out that U have a bad vacuum leak where egr tube goes into upper intake... missing gasket. https://cimg4.ibsrv.net/gimg/www.chr...905693d4f.jpeg |
(Post 109196)
Sorry. I have:) |
(Post 109199)
Yes, the missing EGR gasket could do it. Either that or the MAF sensor leaking vacuum, causing the engine to rev up...
(Post 109199)
(Post 109199)
Not sure at this point. May try a good scan tool to see it it is throwing any codes...
OEM plugs or an alternative?
| All times are GMT -5. The time now is 06:25 AM. |
