-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   How to check computer fault codes (https://www.chryslerforum.com/forum/chrysler-pacifica-15/how-check-computer-fault-codes-9033/)
Virglijus Aug 17, 2009 12:15 AM
Hello All,
I am the new owner of 2007 pacifica touring 4.0 l FWD. I wanted to check if there are not any computer fault codes and tried to do "key dance" but it did not work. Is it posible to check codes without OBD scaner?
Thanks...
CHRYSLER TECH Aug 18, 2009 08:56 AM
do u have a check engine light on? are u experiencing anything wrong?
Virglijus Aug 18, 2009 11:56 AM
Yes, check engine light is on.
CHRYSLER TECH Aug 18, 2009 03:10 PM
if the key dance did not work then yes U will need a scanner that is can bus
Qckslvr Aug 20, 2009 02:51 PM
All right, I'll bite. What's the "key dance"?
CHRYSLER TECH Aug 20, 2009 09:47 PM
turn the key on and off 3x
Tamban May 20, 2014 02:30 PM
On our 05, set the E brake, put into neutral, select trip odometer, start at key ON, off, on off on off. wait for it... that worked for this model...
