How to install outside mirror
Hello,
My wife managed to do what I thought was impossible: break the passenger side mirror exiting our garage. Got a new mirror but would like to try installing it myself. Where could I find a manual explaining how to do that? I appreciate all your help. Thanks a lot! |
RE: How to install outside mirror
[ol][*]Using a trim stick C-4755 or equivalent, move the front door frame molding. (Refer to 23 - BODY/DOOR - FRONT/MOLDING - REMOVAL).[*]Remove door trim panel and water dam. (Refer to 23 - BODY/DOOR - FRONT/TRIM PANEL - REMOVAL).[*]Disconnect the electrical connector, if equipped (MIRROR WIRE CONNECTOR).[*]Using a trim stick or equivalent, remove the mirror flag stuffier.(FOAM STUFFIER).[*]Remove the nuts attaching mirror (SIDE VIEW MIRROR).[*]Remove the mirror from the door[/ol]door trim panel
[ol][*]Release door latch and open door.[*]Lower door glass.[*]Open remote handle trim plug and remove screw from behind inside remote handle (REMOTE HANDLE TRIM PLUG).[*]Open armrest pull cup trim plug and remove screw from inside arm rest pull cup (DOOR TRIM PANEL).[*]Disengage push-in fasteners attaching trim to door panel around perimeter of trim panel.[*]Tilt trim panel outward to clear locator pins on backside of trim panel.[*]Disconnect trim panel from retainer channel in inner belt weatherstrip at top of door by lifting while gently jiggling. CAUTION: Do not allow door trim panel to hang by the wire connector or wiring.[*]Move top of trim panel away from door, while supporting bottom trim panel.(DISCONNECT DOOR TRIM PANEL).[*]Disconnect inside handle cable end from clip, and pull conduit end out from bracket (FRONT DOOR TRIM PANEL MECHANICAL CONNECTIONS).[*]Disconnect lock knob conduit end from bracket. Slide cable barrel end out from the lock knob and guide cable through slot. Ensure that lock knob cable did not get bent (FRONT DOOR TRIM PANEL MECHANICAL CONNECTIONS).[*]Disconnect wire connector from power door lock switch, mirror switch, power window switch, and courtesy lamp.[*]Remove trim panel from door. [/ol] |
| All times are GMT -5. The time now is 05:23 AM. |
