Idle noise haven't heard in two weeks
Are there any check engine codes stored?
P1684 and other ones that are related to passinger side seat. Also noticed the radiator fans were on during it |
P1684 is a weak battery, or one that has been disconnected.
1st thing is that modern computer controlled car can run like **** when there is a weak battery. Go do advanced auto and get a cheap mechanic stethoscope. That should help you track down that noise. One thing I want to mention. My previous car a 3.5 liter 04 Intrepid made a very similar sound to yours about two weeks after I got it. It turned out that the crank bearings were shot and moving so that they covered the oil passages. It would sound like crap and die, but the next day it might have run fine. The stethoscope should get you closer to tracking down the source of the noise at least. |
Thanks for the tip. Lovely.. Just what I need. Did you get it fixed or sell the vehicle? I have a appointment for my mechanic Friday and worse possible time for car problems.... |
I bought a Jasper motor for it.
Noise is back
The noise is back at idle. I turn it off and it does it. My machanic put a new serpentine belt and it did it the next day and took it and of course it doesn't do it when I'm at the machanic and it does it again today 4 days later |
