INTERIOR LIGHTS PROBLEM
I have a '05 Pac and now the interior lights won't turn on when they are pressed but they still work when I open the doors or use the manuel switch on the steering wheel. My husband checked my fuses and they were all working. Does anybody know what this problem is?
RE: INTERIOR LIGHTS PROBLEM
the dome or the reading lamps do not work correct? if yes possible BCM or M27 CKT is broken.
Yes, and it's not just the front ones, it's all the reading lamps. Do you know how much that costs and is it something that my husband can fix? [sm=thanx.gif]
cost no I dont know what BCM u have installed and possibly u wont be able to install the BCM and have it work correctly It has been awhile sence I have install a BCM on a PAC. The installing is not the issue its once installed and proraming it if required would be the issue.
what is a bcm, i have the same problem in my 06
try un hooking the battery for a few minutes or removing the IOD fuse for a few to kind of "reset" or "reboot" the module (s) and see if it works again. Might be a temporary or longer term fix. ON mine, the power locks would not work by remote, or hitting switches on the door. After pulling the IOD fude for a few minutes and putting it back in, the locks work fine now. this had been for 2 months now. The IOD fuse in in the use box and labeled so. Maybe fuse 24?
