-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   Location of Bank 1 camshaft postion sensor (https://www.chryslerforum.com/forum/chrysler-pacifica-15/location-bank-1-camshaft-postion-sensor-29641/)
PappyGoodwill Jul 12, 2018 12:01 PM
2005 Pacifica, 3.5L, OBD code P0340, Bank 1 Camshaft Postion Sensor Circuit. I am under the impression that bank 1 is the rear bank, next to firewall. Okay, so where the heck is is the sensor?!? Am I mis-informed of which is bank 1? I can see the (alleged) bank 2 sensor behind the alternator. I see nothing resembling the bank 2 sensor on the (alleged) bank 1. I have employed flashlight, mirror and snake cam in searching, both above and from underneath the vehicle. I'm aware that there may be other causes for the code, but I'd like to try the easiest (no-co$t) solutions first. Ya, know, like checking for loose connector or cut/broken wire.
CHRYSLER TECH Jul 13, 2018 11:52 PM
only one cam sensor
PappyGoodwill Jul 16, 2018 01:08 PM
Okay, my next question is, why am I getting a Bank 1 error code when there is only one sensor on Bank 2? Or, again, is the forward bank not Bank 2? I have checked the connector On the "alleged" Bank 2 sensor and it shows 5 volts. Is the ECM viewing the only sensor as Bank 1? Why is the sky blue?
CHRYSLER TECH Jul 16, 2018 11:24 PM
your looking at a basic scan tool with generic info p340 just means cam sensor circuit failure. the other 340s will be the other codes and then get into the second cam sensor if equip this car only has one. IF you want a diag break down of how to check it out voltage ect using laymans terms get a haynes manual or one comparable.
PappyGoodwill Jul 24, 2018 01:48 PM
Turns out it was the water pump. Silly, me! Duh! Timing belt drives water pump. Water pump goes boom. Water pump gear eats teeth off timing belt. Timing belt not in the mood to turn camshaft. Camshaft sensor whines. Computer interprets whining as a problem in the sensor's circuit. Geez, any idiot could have thought of that. Maybe that means I'm not an idiot.
