low side service port - Hey Moe!
'04 Pacifica.
Trying to hook up my gauge set to check pressures. Found the high side port near the right shock tower. Only other port I see is on a plastic line with a green screw-on cap. line is not the right size for the low-side fitting. Special connector? or is the low-side service port hiding on me? Thanks, AL |
RE: low side service port - Hey Moe!
Service manual says '....suction (low side) service port. This port is on the
A/C suction line located near the A/C expansion valve at the rear of the engine compartment.' Must be hiding - will look again :) |
Removing the air filter housing lid will aid in being able to see the port.
