malfunction indicator light
this light just came on this morning - i have checked the gas cap, it was loose so i tightened it. that did not help
I researched and found out how to get the code associated with the light and it is P 0420. What should I do now? I dont have a lot of money to spend on repairs, but my car is under a warranty. thanks for any help:( |
That is the code that tends to be associated with the fuel system ...and a loose gas cap.
The code may clear itself in a couple of days. You code also purchase an OBD2 reader and clear the code yourself. Cheers! |
Originally Posted by theblondeone
(Post 67365)
I dont have a lot of money to spend on repairs, but my car is under a warranty. Duh. |
to dcotter0579 - please do not respond to anymore of my threads, as i am here for help, not sarcasm.
(Post 67390)
As a Moderator on another site, if you are having issues/problems with another member, send a PM to one of the site Moderators. They will look into it and take action as required/needed. BTW, I agree with you. His post was neither informative nor helpful. Don't get discouraged!! Cheers! |
this is where common scene is earned and not born with sorry
"I dont have a lot of money to spend on repairs, but my car is under a warranty." No money under warranty no pay DO it yourself guess spend time and money u dont have which would U like to do? |
Originally Posted by Grenadiers
(Post 67391)
"I have a problem with my car. I have a warranty. What should I do?" |
Neither dcotter0579 nor Chrysler tech have posted a response to what the code p0420 means. Do you know or not? If NOT, then keep your opinions about what I SHOULD do to yourself. Also, Chrysler tech, if you are such, your first response should've been an answer to the code, obviously you are lacking in common sense area yourself.
yeah common enough sense to know not to tell u so yeah buddy do home work open up Google.com type in p420 OBD code its federal emissions code its basally a a BS code.
Here:
P0420 Error Code: Catalyst System Efficiency Below Threshold (Bank 1) "I researched and found out how to get the code associated with the light and it is P 0420. What should I do now?" Your question was "What should I do now?" Next time you want to know "What is the meaning of this code?", try phrasing your question more appropriately. |
| All times are GMT -5. The time now is 02:27 AM. |
