Master Window Control Switch Replacment
Old Dec 31, 2011 | 11:15 AM
fsmclean's Avatar
Default Master Window Control Switch Replacment
Hi,
I have searched everywhere but cannot find info on this matter. The power window toggle switch for my 2007 Pacifica broke off. The windows still works but the actual switch is gone. I purchased 3 other used master control window switches and all have the same issue which is that all the switches (passenger, reaer windows, door lock and mirrors) work EXCEPT for the drivers side window. I put the orginal "missing switch" unit back in and the window works. I have tried disconecting the battery for over 10 mins to reset the computer but no effect.
Any help or ideas would be greatly appreciated.
Frank
Old Dec 31, 2011 | 12:15 PM
if u have the switch with the module built into it then it would need to be programed and a dealer can only do this with the scanner.
Old Dec 31, 2011 | 02:22 PM
fsmclean's Avatar
Default master power window control switch
Thanks for your reply. The switch is built into a module amoungst other switches. So you are saying that the dealer will need to program the module or any switch module installed? Is just seems stange that all switches work but the driver side window. Thanks again.
Meniil
Nov 30, 2014 10:00 AM
thedukesmom1
Oct 23, 2014 11:15 PM
asifakhtar
Sep 23, 2013 10:39 AM
ramonroad
Jun 19, 2012 04:12 PM
bobgfla
Dec 14, 2004 12:17 AM
