Newbie!!!! 08 Pacifica noise
I have a 08 Pacifica AWD and when you are driving it sounds like when you were a kid and you put a card in the spokes of your bike. I thought it was the front passenger side axle but after changing it the noise was still there. I've had it up on a lift and ran it in gear and the noise wasn't as prominent as it is while driving it on the road. Any help would be appreciated and thank you in advance for your help!
I don't think the PTU is ever static. In other words it is always "going". I've never identified any particular sound with my car that I attributed to the PTU. When on the lift were you able to inspect all drive axles and the propeller shaft? Something wrapped around them etc? Just throwing stuff out. Hopefully our pro's will have an idea or two.
I did replace the passenger side front axle as I thought it was the culprit. It goes faster with the rpm's. I guess I didn't explain it in the best way, it does sound like an old Ford power steering pump that is low on fluid but not as loud. Thanks for your suggestions, sometimes the simple most obvious things are overlooked.
bgeise
Nov 5, 2014 03:38 PM
just Matt
Jul 21, 2011 02:30 PM
MOHAMMEDHU2003
Jul 22, 2005 04:51 AM
