"No Signal" On DVD Screen
Just purchased 2006 Pacifica Touring. DVD sound works perfectly but no pic on screen. It shows blue with " No Signal" on it. Any ideas what it could be and how to fix it?
Check for loose or corroded DVD player connector (12 pin). Check for loose or corroded video screen connector. Repair if required. Check for loose or damaged in-line connector.
With harness connected, check for video signal voltage at DVD player and at video screen harness. Place known good DVD into DVD player. Place positive lead of voltmeter on pin 5 (video signal) of the 12 pin connector. Place negative lead on pin 6 (video ground). Readings should be between 0.1v to 2v dc. Good luck on getting this concern resolved soon! |
