Oxygen sensor
Just a few O2 sensor questions.
The 3.5l Pacificas only have 1 upstream sensor right? Advance Auto is trying to tell me there are 2 for some reason.
Is the upstream sensor easy to get at and change from over top of the engine?
What brand is recommended? Delphi, Denso, Bosch?
My voltages on my O2 sensor seem fine but I just got the car with 135k on it and it may be the original O2 so I am replacing it.
Hi a_kracker99,
I just bought a new car for my wife. I took over the 2004 AWD Pacifica. I did a tune up on it as it had 120K+ miles on it. I replaced both O2 sensors and THEN got a check engine light. I went to Adv Auto and had them reset after I'd disconnected the NEG cable for two hours. Two miles later, the check engine light came back on and the same thing when the parts store reset it with the scanner.
I know that I'm good to go, but the car is only recognizing that there is a change in the system. I have no repair manual and can't find one, so I don't know if there is a seperate procedure to reset after changing the sensors.
Go ahead and replace yours, but don't be discouraged if this happens to you as well. Hopefully there'll be a response here in the forum with some advice.
Good luck.
Good luck.
Thanks CHRY TECH, I'm on the way to AdvAuto now to have them replaced. Good info!
Thanks CHRY TECH, I'm on the way to AdvAuto now to have them double checked. The connections fit properly and the tails were the correct length, could they have been for a different model or something? Good info though, much appreciated!
No, I bought Bosch
...they rescanned and the downstream sensor shows the same code twice.
They are replacing that one and I'll try it again. I tried to find a part number on MOPAR to no avail for a cross check or reference to be sure. All I found on emissions is the EGR valve.
