P0403 Please Help
Old May 31, 2014 | 03:14 PM
heitzman's Avatar
Default P0403 Please Help
I have a 2004 Pacifica with 120,000 miles on it. I am getting a P0403 code, I just had the EGR valve replaced and I am still getting this code. I checked the wiring going to the EGR and nothing looks wrong. Does anyone have any ideas or suggestions? Thanks
Old May 31, 2014 | 07:11 PM
heitzman's Avatar
I also checked the wires running from the harness to the two O2 sensors. Could the notorious intake plentum leak be the cause of the P0403
Old May 31, 2014 | 11:54 PM
U will need a scanner to make the EGR tiurn on and off my the PCM and then measure the voltage at each connector pins and see which is missing.
Also how did u check teh wires just look or measure voltage and grounds?
and short to ground?
Old Jun 1, 2014 | 10:08 AM
heitzman's Avatar
I did a visual. I removed some factory tape from areas on the harness that looked kind of rough and found no bare or broken wires. i also made sure all connections to other sensors were good.
Old Jun 1, 2014 | 11:41 AM
heitzman's Avatar
I just noticed, the area under the battery has multiple ground wires attached to the body. One of the ground wires was barely attached, I pulled it off with very little effort. It comes out of the harness that leads up to the EGR area. I hope this is my problem.
Old Apr 18, 2019 | 02:22 AM
sivitec's Avatar
Does this solve your problem?
Old Apr 23, 2019 | 09:38 AM
sivitec's Avatar
Ok, just an update. I checked the ground wire under the battery and 1 of them (the single wire) had a brittle connector that got easily removed. I changed it and haven't seen any error codes yet after a full day ride. *fingers crossed*
Old May 1, 2019 | 10:32 PM
djetelina's Avatar
Hope it works out for you. Your Pac is in the Philippines? Am sure that is an interesting story in itself, must be the only one in country..
Old May 7, 2019 | 09:51 PM
sivitec's Avatar
There's a Chrysler dealership here, but I doubt that they will be able to solve the issue. It's good that we have forum like this where people can support each other
Dsmitty3
Apr 29, 2024 06:48 PM
maintenance
May 5, 2015 08:53 PM
jsiceloffj
Mar 30, 2014 07:17 PM
cmass
Jan 30, 2013 07:23 AM
luu5
Jun 5, 2008 01:57 PM
