-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   P0403 Please Help (https://www.chryslerforum.com/forum/chrysler-pacifica-15/p0403-please-help-22119/)
heitzman May 31, 2014 03:14 PM
P0403 Please Help
I have a 2004 Pacifica with 120,000 miles on it. I am getting a P0403 code, I just had the EGR valve replaced and I am still getting this code. I checked the wiring going to the EGR and nothing looks wrong. Does anyone have any ideas or suggestions? Thanks
heitzman May 31, 2014 07:11 PM
I also checked the wires running from the harness to the two O2 sensors. Could the notorious intake plentum leak be the cause of the P0403
CHRYSLER TECH May 31, 2014 11:54 PM
U will need a scanner to make the EGR tiurn on and off my the PCM and then measure the voltage at each connector pins and see which is missing.
Also how did u check teh wires just look or measure voltage and grounds?
and short to ground?
heitzman Jun 1, 2014 10:08 AM
I did a visual. I removed some factory tape from areas on the harness that looked kind of rough and found no bare or broken wires. i also made sure all connections to other sensors were good.
heitzman Jun 1, 2014 11:41 AM
I just noticed, the area under the battery has multiple ground wires attached to the body. One of the ground wires was barely attached, I pulled it off with very little effort. It comes out of the harness that leads up to the EGR area. I hope this is my problem.
sivitec Apr 18, 2019 02:22 AM
Does this solve your problem?
sivitec Apr 23, 2019 09:38 AM
Ok, just an update. I checked the ground wire under the battery and 1 of them (the single wire) had a brittle connector that got easily removed. I changed it and haven't seen any error codes yet after a full day ride. *fingers crossed*
djetelina May 1, 2019 10:32 PM
Hope it works out for you. Your Pac is in the Philippines? Am sure that is an interesting story in itself, must be the only one in country..
sivitec May 7, 2019 09:51 PM
There's a Chrysler dealership here, but I doubt that they will be able to solve the issue. It's good that we have forum like this where people can support each other :)
