P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
Ok so the car won't start,
I turned the key back and forth 3 times and it threw out this code P 0522 Which is "Engine Oil Pressure Sensor/Switch Circuit Low Voltage" Could this be why it wont start? Also I got an oil change the other day, could they have done something to cause this code? Thanks |
what year? try disconnecting battery ,2 mins and reconnect.
Originally Posted by alaskanJK
(Post 24929)
I turned the key back and forth 3 times and it threw out this code P 0522 Which is "Engine Oil Pressure Sensor/Switch Circuit Low Voltage" Could this be why it wont start? Also I got an oil change the other day, could they have done something to cause this code? Thanks Engine may not start Engine quits or stalls while in the middle of driving Oil pressure gauge reading zero or low Oil pressure indicator lamp illuminated Possible CausesThere are many possible causes for this error code to appear; which include:
