Pacifica Engine Light
Old Jul 2, 2010 | 05:12 PM
samgil's Avatar
Default Pacifica Engine Light
I have a 2007 Chry. Pacifica with 56,000 miles. The check engine light comes on. If I disconnect the battery for 10 min and then reconnect it goes out for awhile. Any one have idea on what could be causing this? The car runs fine. I really need help with this I am on a fixed income and not much money to go to a tech. Thanks
Old Jul 2, 2010 | 07:02 PM
mrfixit454's Avatar
You can take it to an autozone or pepboys, what ever big chain is in your area and they can read the code for you.
Unless you have a friend that has a code reader, they they can help you.
Old Jul 6, 2010 | 02:01 PM
reddjeep88's Avatar
You can also get the code(s) from your instrument cluster. Without STARTING the car, turn the key to run-acc-run-acc-run...then watch the odometer in the lower right corner of the cluster. It will display codes (a letter with 4 numbers) Write those down, then post them here so we can help steer you in the right direction!
Old Jul 6, 2010 | 02:35 PM
Virglijus's Avatar
I also have 2007 Pacifica, but "key dance" does not work. To get codes you need scanner.
07pacificaowner
Jul 6, 2024 06:27 PM
qbasicer
Sep 25, 2012 02:58 PM
RobinVA
Jan 5, 2010 10:18 PM
wildcat1944
Sep 28, 2009 10:14 AM
IAmTheDood
Feb 11, 2009 09:12 PM
