2007 pacifica cranks but won't start
i checked all fuse and relays gave it a shot of either in throttle body it wants to start have fuel to fuel rail the injectors are not feeding the cylinders.replaced crank and cam sensors. parked car would not start next morning any help is greatly appreiciated
Can you clarify..wants to start..with ether? Does it run on the amount sprayed or VERY roughly. How many miles on the vehicle and has the timing belt ever been replaced?
If the check engine light has been illuminated before this suddenly happened there will be diagnostic fault codes stored in the ECM and should be retrieved to help guide you in nailing down the fault. It works a lot better than throwing in parts that may not be the cause of the problem.
sbd9902
02-05-2020 04:05 AM
DanNotTheMan
09-17-2012 01:36 PM
