Passenger Side Pwr Locks, Windows Not Working
Pacifica is only 7 months old (bought new). Last week, the passenger side power windows, door locks and power seats quitworking (left side works fine). Brought into dealership and he said a connector under the right side scuff plate (?) had to be repaired.
Only a week later and having the same issue! Anyone with this same issue? Also...just realized that we frequently turn on the power windows "lock" feature on the driver's side to prevent our dog from accidentally rolling down the windows. Ourson also has his portable DVD player constantly plugged in. Wondering if either of these two things could be causing this issue? Any help would be appreciated :) |
RE: Passenger Side Pwr Locks, Windows Not Working
take it back to them and let them repair it under warranty
I have a 2005 Pacifica and guess what? The whole passenger side does not work: windows, locks, mirrors. I also just foud the drivers side rear locks not workingn either. The driver's lock is the only lock in working order. And guess what? I am OUT of warrenty. NICE!!
Any fix without breaking the bank? |
Auto Up window not working
I have a 2006 300C and the auto up feature for the drivers window is not working, the auto down works fine. This has happened before but within a day or two it was ok. I also have had issues with the rear passenger window driver side not working, and the auto locks not locking when you reach 15 mph,and they wouldn't lock by pushing the button. I also think that from time to time that my tilt wheel does not always return to the set position. I've never had a car with so many electrical issues. Can anyone offer any help?
RE: Auto Up window not working
the window issue press and hold the windows switch down untill it is all the way there and hold it for 5 seconds then same motion press up and hold it there for 5 seconds at the top.
if that did not work here is a TSB for the up issue. This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retreival system, or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation. THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-011-07, DATED MAY 18, 2007, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES AN ADDITIONAL VEHICLE WITH CLEAN DATES. SUBJECT: Inoperative Power Window Express Up Feature OVERVIEW: This bulletin involves replacing both door modules. MODELS: 2005 - 2007 (LX) Charger/ Magnum/300 **2006 - 2007 (LE) 300C/300C Touring (International Markets)** NOTE: **This bulletin applies to LX models built before March 1, 2007 (MDH0301XX) and LE models built before May 24, 2007 (MDH0524XX)**. SYMPTOM/CONDITION: The express up feature in the power window system may be inoperative or intermittently inoperative. DIAGNOSIS: If a customer indicates that the condition is present, perform the Repair Procedure. PARTS REQUIRED: Qty. Part No. Description 2 56038720AP Door Module (without Memory Mirror System) 2 56038722AP Door Module (with Memory Mirror System) 2 04602838AC Door Module (2007 With Sales Code LEC) REPAIR PROCEDURE: 1. Using the procedures outlined in the Service Information available on TechCONNECT, Group 8, Electronic Control Modules, remove both door modules and install the new door modules listed in the “Parts Required” section. |
Hey thanks Chrysler Tech. I did what you said and the window is now working properly. Is this something I will have to do from timeto time or will it eventually need the new parts?
It's a great car, love the Hemi power and the transmission is the smoothest I have ever owned, but I get bummed with the electrical gremlins. Thanks again-----Dennis. |
what u just did was relearn the express settings if u hold the switch down and not just press it down it will learn that setting all u did was relearn it the only other time u need to do that is if u disconnect the battery.
| All times are GMT -5. The time now is 11:50 PM. |
