-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   PLEASE HELP!!! Drivers side lights not working (https://www.chryslerforum.com/forum/chrysler-pacifica-15/please-help-drivers-side-lights-not-working-14691/)
Chris Walker May 18, 2011 06:29 PM
I just bought a used 2005 Chrysler Pacifica. Did not notice til last night that the drivers side taillight was out. Looked further and the two drivers side front running lights are out also.
Brake lights, and headlights are working fine. I switched the good bulbs from the passenger side over to the drivers side with no result.
Where do i start?
Chris Walker May 22, 2011 01:07 PM
Ive gotten the driver side running lights to come on, but they will only stay on for a few minutes.
I unhook the negitive battery terminal, unplug the wire harness from the fuse box and blow it out. Put it back together and they will come on. I take it out for a test drive and about 10 minutes of driving they will cut off and not come back on.
Anyone have any ideas??
TNtech May 23, 2011 10:44 PM
Sounds like the IPM has gone fruity. Or a ground is coming loose somewhere.
revfast Jan 28, 2013 02:54 AM
Im having a similar issue but with the passenger side headlight, did you find a fix for this ???
CHRYSLER TECH Jan 28, 2013 08:44 AM
The IPM more then likely needs to be replaced
revfast Jan 29, 2013 11:26 AM
what am i looking at as far as hrs needed to get this replaced and price of part ?
CHRYSLER TECH Jan 29, 2013 10:22 PM
parts price call your dealer and I dont have a listing for the book time either.
revfast Feb 1, 2013 08:48 PM
well what I did was reseat all of the relays and fuses on the fuse block in the engine bay, I also moved the fuse block out of its craddle by pressing all four tabs and reseated all of the connections in the back, two days running and I have yet to have the problem.
CHRYSLER TECH Feb 2, 2013 12:25 AM
it will return
Daveh2020 Sep 14, 2021 08:17 AM
Where do i start?
So so where should I be looking in the fuses or is there something else
On the driver side marker front marker out rear running light out what would be the problem where to look
