Position Lights / Interieur Lights
Hello,
just a question. My 04 Pacifica AWD has small lamps in the upper corner of each headlight. Also there are small bulbs in the lower corner of the rearlights. Are these lights positioning lights or whatelse? How can I enable these lights? My car was imported to Germany. Could it be that there is a switch or fuse to enable / disable them? My other question is: Are the buttons on the steeringwheel normally illuminated or not? Is there a bulb in the steering wheel? I hope somebody can give me some tipps. Best regards from Germany Markus |
RE: Position Lights / Interieur Lights
no lites in steering wheel not sure about the outside lites
Last night I just noticed the little "side" bulbs in my headlights as well. Are they burned out blinkers?
they should lite up when your turn lites on they are side marker lamps
Pacman: They do not get on with the markers! I tried this also! I think they are "day lights". In the US most of the cars have lights which are on all the time - day and night. In Germany this is forbidden, so I thought there is a way to enable them again.
Does anybody know for what these bulbs are? |
Pacman: I missunderstood you! But also when the light is on they do not lite up.
when my lites are on the side marker are amber in color i think in germany amber side la mps are not allowed so might be disconnected
where in germany are you im planning to bye a crossfire that is built their i live in florida
my name is dennis need your responce |
het bumu are you still out there
I figured it out.
They only come on when you remove the key and exit the car. They come on to help light your path. The replacement bulbs are like $2.89 US |
