Possible to get a vin history:
Hi would it be possible to get a vin history, Im looking at a 05 pacifica with 50000 miles,
looks like needs tires shocks struts front end out of alignment, vin 2c4gm68415r441646 thank you in advance. Any suggestions on other things to look for, oh did note the oil level was at the add mark, owner had oil changed 900 miles earlier, but dont know if shop put in 5 qts or 5.5. so I guess if only 5 qts was put in would the level indicate a qt low on the dip stick? Best wishesMax |
RE: Possible to get a vin history:
no open recalls
March 9, 2007 67033-GREEN CHRYSLER 26860303-Maintenance-Lube, Oil, and Fil 245443 44,767Miles 2007032 SERVICE CONTRACT December 14, 2006 67033-GREEN CHRYSLER 18F44182-PCM Update-Reprogram Powertrai 241254 41,596Miles 2006123 RECALL REPAIR December 14, 2006 67033-GREEN CHRYSLER 26860303-Maintenance-Lube, Oil, and Fil 241254 41,596Miles 2006123 SERVICE CONTRACT September 1, 2006 67033-GREEN CHRYSLER 26860303-Maintenance-Lube, Oil, and Fil 236183 38,322Miles 2006091 SERVICE CONTRACT June 20, 2006 67033-GREEN CHRYSLER 26860303-Maintenance-Lube, Oil, and Fil 232301 35,218Miles 2006064 SERVICE CONTRACT April 24, 2006 67033-GREEN CHRYSLER 26860303-Maintenance-Lube, Oil, and Fil 229393 31,862Miles 2006054 SERVICE CONTRACT November 2, 2005 67033-GREEN CHRYSLER 07500112-Pump, engine water-3.5 liter e 220409 25,244Miles 2005115 WARRANTY [/align] |
RE: Possible to get a vin history:WOW
Thank you very much!!
Best wishes max |
