power seat on 04 pac
My driver seat on my 04 pac recently started to malfunctioning . Problem is that when I try to move seat back it only moves from one side of the track and it gets stuck .I have not removed the seat yet . I was wondering if anybody here has any idea why its doing this. Are there two motors that run the seat? And if so can I replace just one motor.
Any ideas or past experiences would be helpful ,thank you !! |
There may be more than one motor in a power seat, but there will not be more than one motor controlling a single movement. There may be something stuck in the track, like a coin or pen that fell out of your pocket and wound up getting where it doesn't belong. You will need to get under there and see if you can find the obstruction.
ok i will look into that
I took out my seat yesterday to look if I saw anything getting it to get stuck but there was nothing there. I did notice that only one side of the track was moving and not the other.
question:is there only one motor that operates the back and forth movement of the power seat? I did see three motors Any ideas would be great!! |
Thanks for the lack of help guys .....great forum!!
How do you adjust a power seat if there was a manual seat there before?
I replaced my broken manual '95 dodge caravan driver's seat w/ a power '99 driver's seat. The wires underneath the seat don't match. Is there an adaptor to make these work together? Is there some way to manually adjust the seat? Is there any problem not having the wire from the floor of the van connected to the seat? |
