pure valve test port
Old Jan 29, 2018 | 01:43 PM
corvairbob's Avatar
Default pure valve test port
anyone happen to have a picture of the purge valve test port. when i was working around that area doing the timing belts and serpentine belt i had to move the purge valve out of the way and i did see the purge linse from the nvld and to the pvc but i did not see anything that looks like a test port. if anyone knows where that may be located or a picture of the location it may help with testing the system this weekend. i found a great youtube on the chrysler evap systems from the late 90's till today. i still have the 457 code and i want to smoke the system using that test prot if i can find it. also if the test passes i will then take out the nlvd and test is separate and if that passes both pressure and vacuum plus electrical then i have to drop the tank to see what is going on there. i'm going to find the issue and fix it just because i want it to work. but looking for some shortcuts if i can find them.
thanks
jzabi0079
Jan 26, 2009 07:03 AM
luv2byte
Aug 22, 2008 08:51 AM
goldsmi
Jun 7, 2008 02:28 PM
sumncguy
Jul 24, 2007 09:35 PM
lucy_30
Jul 6, 2005 10:38 PM
