radiator cooling fans staying on
posted this problem before. when I start the car radiator
cooling fans coming on about 5 seconds after starting. someone had posted make sure a/c is not on, and when I tried starting with the a/c on they would come on, when starting with the a/c off they wouldn't. Now, they are coming on with the a/c off or on, and are never shutting off. coolant level is ok. Read a little in the service manual, mentioned a/c pressure transducer. Don't know where to start. But they were shutting off about a week ago, now they never shut off, even when the engine is cold. |
RE: radiator cooling fans staying on
defrost on?
no, don't even have the power switch on. so nothing is on. wondering if I should go buy a drbIII scannner. think it would help at all. Service manual is going to send me in several different directions, a/c pressure transduce, fan relay, coolant temp sensor.
guess I won't be buying a drbIII scanner, did not realize how much they were.
Autozone will scan for free, if there are any codes. Have them scan it and post the code.
| All times are GMT -5. The time now is 02:43 AM. |
