Radiator fans do not come on
Disconnected rattling fan on drivers side while I wait for a new one to arrive, but, neither fan will come on now after driving and idling for quite a while. Temp outside is 19 deg so maybe they won't come on. However, is there something that needs to be reset after disconnecting one fan.
I'd be surprised to see a fan come on at 19 degrees ambient. Any indication of overheating?
No overheating
Just making noise. I am going to change it this week. Just seemed strange that they wouldn't come on at all seems like they would kick on before at any temp. I let it idle for quite a while, but, thanks I won't worry about it. I have the noisy one disconnected so it won't come apart.
they are series fans both must be connected to work.
Do both the fans have to be replaced as a unit?
Thanks, makes sense.
Can you just replace the one fan? Or do you have to replace both as I see them sold as a unit? |
replace both
Thanks, I'll order both. Doesn't look like too big of a project to change.
(Post 44513)
replace both
Just a quick question, but I have to ask......
Does this happen with the defroster on???? Doubtful the coolant sensor is bad, because there is no dedicated sensor for the fan. There is an Engine Coolant Temp sensor, which feeds PCM with coolant Data and in turn PCM will activate the relay to turn the fans on....If there were a problem as you describe, It would most definitely either set a C/E light, or cause other driveability issues in another area. Now...During defroster usage, your A/C compressor is activated to de humidify the incoming Air....When High side pressure exceeds predetermined limit, The fans will operate to avoid Over pressure, and since The condenser and pressurized freon produce their own heat, it will have very little rhyme or reason as compared to outside temps. |
Originally Posted by Djinn-n-Tonic
(Post 48762)
Does this happen with the defroster on???? Doubtful the coolant sensor is bad, because there is no dedicated sensor for the fan. There is an Engine Coolant Temp sensor, which feeds PCM with coolant Data and in turn PCM will activate the relay to turn the fans on....If there were a problem as you describe, It would most definitely either set a C/E light, or cause other driveability issues in another area. Now...During defroster usage, your A/C compressor is activated to de humidify the incoming Air....When High side pressure exceeds predetermined limit, The fans will operate to avoid Over pressure, and since The condenser and pressurized freon produce their own heat, it will have very little rhyme or reason as compared to outside temps. they run normal (as expected) when AC an/or defroster is activated. I just found it odd that sometimes they would be on after I just exited the highway when we know no cooling fans are needed for only heat or just the cabin "fan" being on, heat or no heat. |
| All times are GMT -5. The time now is 06:25 AM. |
