Rear back-up camera
Hi,
I have a 2004 Chrysler Pacifica AWD came with navigation system and back seat dvd screen, where can i find a rear back-up camera that will work with the car, will any of them work? thanks eric |
RE: Rear back-up camera
Have you found anything? Does anyone know if the indash monitor has video inputs? Thanks
I checked into running camera into the Nav but according to car diagrams in uses an R-G-B input . So in theory you could buy a RGB adapter and? So instead I got a camera that mounts to the license plate and a rearview mirror with a 7" lcd screen and bluetooth built in for around $235 for everything ($135 for mirror, $100 for camera).Not too tuff to install. plus now I can see my DVD menu screens up front to start DVD audio discs.
timtec,
Can you share with us what and where you got your setup? I just purchased a 2004 with the nav and would like to have the rear view camera. If you have any pictures or detail that would be helpful. RonVF ronvf@yahoo.com |
Here is a mirror and camera on ebay like the ones I got:
http://cgi.ebay.com/ebaymotors/Newes...spagenameZWDVW http://cgi.ebay.com/ebaymotors/CCD-L...spagenameZWDVW http://cgi.ebay.com/NEW-7-BLUETOOTH-LCD-TFT-Car-Rear-View-Mirror-Monitor_W0QQitemZ250201550590QQihZ015QQcategoryZ14 9976QQssPageNameZWDVWQQrdZ1QQcmdZViewItem And a guide I followed from another post: Wiring, DVD Jumper, Instrument panel 04869298AB Wiring, DVD to Screen Up to 3/03/03 04886399AE Wiring, DVD to Screen After 03/03/03 04869431AB The first cable is what actually plugs into the back of the DVD player. It lists for $69.70(paid $52.28) The DVD to Screen lists for $47.85(paid $35.89). This is what we ordered first as we were deceived by the description. This is actually the cable that would plug into the flip down screen. I did cut the cable (opposite end of what plugs into the DVD) and soldered on RCA connectors from Radio Shack. This plugged right in to the box for the Sony monitor. Here is a pin out for the DVD player and wiring harness. 1 Grey/Tan Fused B(+) (didn't use, used power from 2nd row power outlet instead) 2 Yellow/Grey Igition/ACC signal 3 No connection 4 No connection 5 Grey/Lt Blue Video Control(didn't use) 6 Grey/Orange Video Signal(This is center for RCA connector) 7 Grey/Dark Blue Video Return(didn't use 8 No connection 9 Violet/Orange Video Play Signal (didn't use) 10 No connection 11 No connection 12 Shield (This is outside of RCA connector The DVD cable if you have the rear DVD player runs up the right side A-Pillar and this is where I tapped in.to get my video signal for the DVD. Got the power for the mirror from the overhead console amd the camera wire was ran along the right side where the headliner meets the tops of the doors. The camera mounts to the top license plate bolts and you need to drill a hole in the light post above the license plate. Run the wire up the tailgate (you have to take tailgate panels apart) and fish it through all the other wires running through the rubber boots to the top of the tailgate till you get it to the right side of headliner.This is the hardest part of the whole job. From: "Subscription notification from Chrysler Forum" <support@chryslerforum.com> To: <no-reply@liwh.com> Sent: Thursday, January 03, 2008 10:09 PM Subject: Subscription: RE: Rear back-up camera - by RonVF | Chrysler Pacifica RonVF at 1/3/2008 7:09:28 PM ~~~~~~~~~~~~~~ RE: Rear back-up camera ~~~~~~~~~~~~~~ timtec, Can you share with us what and where you got your setup? I just purchased a 2004 with the nav and would like to have the rear view camera. If you have any pictures or detail that would be helpful. |
