-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   Running a wire Trough The Firewall (https://www.chryslerforum.com/forum/chrysler-pacifica-15/running-wire-trough-firewall-14854/)
WRXCarl Jun 6, 2011 06:34 PM
nulll
Djinn-n-Tonic Jun 6, 2011 07:21 PM
remove the left side inner fender liner, and follow the factory harness into the grommet. That will leave you about 8 0r 10 inches up the left kickpanel.
SARG Jun 9, 2011 01:56 PM
I snaked several wires down through the side of the firewall on the passenger side. Passes around the side of the wall alongside the inside of the fender. From the inside pull down the liner under the glove box and you'll see the easiest path.
I ran several wires while I was at it .... and sure enough I have used them all now for lights etc.
WRXCarl Jul 11, 2011 01:16 AM
Thanks for the responses both sound simple just need to find the time to do this now ... busy busy busy:cool:
Tower Master Apr 10, 2015 09:46 PM
installing fog lights
Just saw this info, I would like to try this on some fog lights in the future. I will have to remember this.
Thanks people.
salvonrico@verizon.net Apr 11, 2015 05:32 AM
Fog lights
Just saw this. Will work great for me. Thank you guys, for the tip.
kcunning728 Apr 17, 2015 04:08 PM
Running wires
Well as it be. My 07 Pac was prewired from factory so all I had to do was order the turn signal switch with the foglight switch on it. But I will do this option to wire up another mirror that has a compass and thermometer.
