-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   stop the shake (https://www.chryslerforum.com/forum/chrysler-pacifica-15/stop-shake-26104/)
evoo615 May 31, 2016 01:06 PM
stop the shake
New to the site, just got a 2007 Pacifica, about 6 months ago and love it. I had a problem with the starter clicking some time and then start right up. After looking around on the big wide web., I Found that it was not getting a good ground to the motor, so I ran a 4 ga. Wire from neg. battier. Post to a bolt on the transmission and have not had a problem with that. Know the next problem is when I hit the brakes it shakes like when you have warped rotors. I changed the rotors and brake pads on the front but that did not fix it, I have no ABS lights on , at low speeds not much of a thing, but running on the interstate and having to get on the brakes it shakes a lot. Does anyone have a suggestion what I might be up against? Thanks in advance
dcotter0579 May 31, 2016 08:59 PM
Check the ball joints up front including the tie rod ends.
hocus May 31, 2016 09:17 PM
Check the engine support and for any loose nuts and bolts that holds the engine.
musty Jun 22, 2016 10:04 AM
+1. sounds like either tie rod ends or control arms to me. also grab yourself a repair manual and make sure all front suspension bolts are torqued to spec. a loose one can definitely cause that same shimmy.
