strut rod torque
I replace the front struts and springs on my 04 pacifica and I can't find anything with bolt torque specs for it. I need the specs for the strut rod. Thanks
I just run mine down with a air gun. never had a problem.
40 ft-lbs if you can figure out how to get a torque wrench on it while holding the rod from turning.
Using an impact wrench for assembly is a bad idea if you can't control the torque. They are great for disassembly work. |
(Post 75413)
Using an impact wrench for assembly is a bad idea if you can't control the torque. They are great for disassembly work. Just saying. |
