Transmission Leak
1 Attachment(s)
I was currious if anyone has experienced leaking transmission fluid for the cover that I highlighted? If not, does anyone know if I can just drop that pan and reseal?
Hi there,
I have the same problem? I just noticed last night, did you fix it? Is the seal or something else. Thank you S |
A few things come to mind.......
Make sure the leak is NOT coming from the Axle seal housings,or the PTU joint. since fluid doesnt Leak in an UPWARD direction, it can be very easy to mistake a leak at the diff cover from fluid that has "Blown around From driving. Next remove the cover and ensure the housing isnt cracked (Somewhat common) The good news is.... If youre sure it is a cover leak, reseal it with RTV silicone and call it a day. There is no gasket available, and there never was, rtv was used from the factory. |
Originally Posted by cowli4nia1
(Post 55263)
