trouble shooting trailer wiring harness
Hello All,
I am having a problem with a 2004 Pacifica trailer harness. The brake lights work on the vehicle but not at the plug. I am making the assumption that the harness combines the turn signals and stop lights. Any help would be appreciated. Thanks georgeo |
RE: trouble shooting trailer wiring harness
did u use chryser wire harness or aftermarket one?
ORIGINAL: georgeo Hello All, I am having a problem with a 2004 Pacifica trailer harness. The brake lights work on the vehicle but not at the plug. I am making the assumption that the harness combines the turn signals and stop lights. Any help would be appreciated. Thanks georgeo |
Yes sir, it's a Chrysler harness. The numbers on the tag read 82208221 and 23489A if that makes a difference. Using a test light, I get power for tail lights, one with constant power ( don't remember which one) and both turn signals but no brake.
Thanks georgeo |
ORIGINAL: Sierrasan [/quote] Hello Sierrasan, Thanks for the tip , I'll check it in the mornig and report back. georgeo |
Checked the number 10 fuse ( blue 20a) and it looked good and has continuity. Anything else I should check?
Thanks georgeo |
