water leak 3.5 2006
my gf has a 06 3.5 pacifica and it is leaking cant find where checked lower hose not problems it drips when ideling but when you turn off car it downpours any ideas
get a pressure tester and pup up to 17 PSI then u will find it
I have this problem currently, BUT mines downpours from the metal shield behind the belts to acces the Timing Belt/Water Pump. I removed the passenger tire, started the car and once the pressure built up, presto, found the guilty party. I've yet to change the part yet but will be doing so this weekend. Hope this might help with locating the leak.
