water leak
Old Mar 18, 2008 | 09:58 AM
golfdogg's Avatar
Default water leak
I have a 2004 Pacifica and water is leaking in where the bolts hold the driver side visor and also at the top of the post where the fabric meets the plastic piece. Is there an easy fix??
Old Mar 18, 2008 | 11:51 AM
mrfixit454's Avatar
Default RE: water leak
Do you have a sunroof?
Old Mar 18, 2008 | 04:09 PM
golfdogg's Avatar
Yes I do.
Old Mar 18, 2008 | 11:25 PM
mrfixit454's Avatar
Not sure about an easy fix. Have you checked to see if the sunroof is closing all the way? Is the seal still in place? Is there any debris (leaves) in the tracks when the sunroof is open?
Old Mar 19, 2008 | 11:07 AM
levistar's Avatar
Also make sure the drains for the sunroof are clear. You will need to blow compressed air through the tube openings.
Old Mar 19, 2008 | 06:13 PM
golfdogg's Avatar
Ok I will try blowing out the drain tubes.The sunroof is closing all the way and there isn't any debris in the tracks. When I go through the auto car wash thats when the water really comes in .
Old Mar 19, 2008 | 07:56 PM
Al B's Avatar
I too would guess that the drains are plugged.
Old Mar 20, 2008 | 11:40 AM
Dustymedic's Avatar
Is it a factory sunroof, or was it installed afterward?At lot ofafter market sunroofs, the installers give lifetime guarantees. I had the same problem about a month ago (On a day with a one inch rainfall) & the installer was able to clear it out and reroute part of the drain line to reduce chances of it happening again in about 20 minutes.
ranger 22
Dec 12, 2018 01:56 PM
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
musicfreak2195
Jul 7, 2009 02:23 PM
ranger 22
Jan 1, 2005 05:45 PM
