Weird clunking noise coming from the front end
I had the front brakes done on my '04 Pacifica about a month ago. Stops like a dream now, and no squeaking coming from the pads. But I've noticed that when I go over rough pavement/potholes/or even railroad tracks, I hear a clunking noise coming from the front end.
I did some searches and have seen some probable causes (lower and upper control arm bushings, loose struts, etc.). I am going to check things over tomorrow morning to make sure there isn't anything obvious. But here's where it gets strange. If I go over that same rough pavement and apply the brakes very lightly (not heavy enough to even slow the car), the noise completely disappears. Any ideas? |
While you're under there looking around, grab the calipers with both hand and give them a good shake. If you feel any looseness, take it back to where you had the brake work done and have a chat with them.
Other than that, "weird noises" are basically impossible to diagnose over the internet. |
Will do. I definitely think it's in the calipers, because the noise completely disappears when I lightly apply the brakes.
I know what you mean about diagnosing weird noises over the internet! But nonetheless, I appreciate the help on this one. |
Based from what you mentioned, try to check the stabilizer links as well.
| All times are GMT -5. The time now is 06:25 AM. |
