weird feeling on front end
hello , when turning on curves, it feels as thought your on ice , the front end seems to want to drift, then a second later its ok. only feels that way when going over 6o kms/per hour. any ideas before i take it to the shop as my engine light has just come on. thanks guys. fred
RE: weird feeling on front end
What type of light came on? I ask because the service light is for your own use and you can reset it for oil changes and such.
the engine light came on , as the engine is running rough, when you push on the gas pedal its like it wants to stall, nothhing happens when you feather the pedal, then when you tromp on it it takes off. nothing to do with that drifting feeling im getting on the front end, but it sure feeels weird. would be good to know how to reset the service light though , like you say for oil changes and such. thanks fred
Go through the menu and you will see where it says to reset the service interval. You can also change the interval if you like. It's not difficult. If you still have trouble check your manual. It's hard to be exact in the steps to take when I'm not in the car.
