What does this warning mean?
Have '04 Pacifica. EVIC went out 2,000 miles ago. Car is running great, however, as we are going down the road, the warning bell rings three times waits about 10 seconds and does it again repeatedly. With the EVIC out, I can't see what the problem is. Anyone have a clue? I was also told by someone that the EVIC problem could be only a fuse, is this possible?
Thanks! |
RE: What does this warning mean?
seatbelt (usually does three rings over and over with pauses inbetween), or low on fuel. Just taking a stab.
Try to find someone with an OBDII code reader. Maybe it will show what is going on. You can purchase them relatively inexpensive, or do like I did, bite the bullet,and buy a Dashhawk, (http://www.dashhawk.com/). Well worth the $$, IMO, if you really want to know what is happening in all your late model (OBDII equipped) vehicles. Among 100 plus things it is capable of reading, it also reads error codes, and clears them, too.
Any Autozone or Advance auto parts will hook up a reader for free and tell you what the errors are.
u only need an obd2 code reader if u have a check engine light on only. Tehy cant get into the body or evic computer.
